Routing Sheet Variables Lists
The following table lists variables that are available for Routing Sheets. For a list of other variables that can be used in Routing Sheets, see List of template variables (in alphabetical order).
Variable
Description
%ROUTINGSHEET_TITLE%
Title of the Routing Sheet created by the end user
%OMEDID_BARCODE%
The barcode image is replaced with this variable
%SENDER_EMAIL%
Sender's email address
%ROUTINGSHEET_DATE_CREATED%
Date the Routing Sheet was created
%ROUTINGSHEET_DATE_EXPIRES%
Date the routing will expire (if applicable)
%ROUTINGSHEET_SINGLE_USE%
Indicates the Routing Sheet is single use
%EMAIL_DESTINATION.1%
First email recipient’s email address (The number indicates how many email recipients to list.)
%EMAIL_DOCTYPE.1%
Final form to be sent to the first document management location
%PRINT_DESTINATION.1%
First printer recipient
%FAX_DESTINATION.1%
First fax recipient
%UNC_DISPLAY_DESTINATION.1%
First network folder recipients
About Routing Sheets
Creating Routing Sheet Templates Guidelines
Supported Bar Codes
