Adding a XeroxScan Connector
You can add a XeroxScan connector by using the Server Administrator > Connectors node.
To add a XeroxScan connector
  3. Right-click Connectors. Select New AccuRoute Server connector > XeroxScan Connector. The Server Address dialog box appears.
  4. Click Next. The Display Name dialog box appears. Alternately, if you want the connector to run on a remote server, click Remote Server and enter the server name. Click Next.
  5. In the Name text box, enter an appropriate name.
  6. Click Next. The XeroxScan Default Originator dialog box appears.
  7. Enter the default originator email address. This information is used as the sender email address if the job information does not include a sender email address
  8. Click Next. The XeroxScan default settings dialog box appears.
  9. Enter the path to the scan repository. You can also browse to the location.
  10. Click Next. The Congratulations dialog box appears.
  11. Click Finish. The XeroxScan connector is listed in the details pane.
Note: Before the XeroxScan connector can start collecting scanned documents from a Xerox MFD, you must define a repository in the XeroxScan connector. For instructions, see Add a XeroxScan connector repository.
About XeroxScan Connector
Upland AccuRoute Server, Fax and XeroxScan Connector
About Xerox Connector Default Destination and Format
Configuring Xerox Connector Defaults
About XeroxScan Connector Network Scanning Templates
Adding a XeroxScan Connector Repository
