About Xerox Connector Default Destination and Format
When a document enters the Upland AccuRouteserver via the XeroxScan connector, the connector analyzes the document. If the document does not have a destination associated with it, the connector applies the default destination configured in the XeroxScan connector properties. For instructions on how to configure the default destination, see Configuring Xerox connector defaults.
Xerox Connector Default Destination Format
The most common method of sending outbound faxes through the XeroxScan connector on the server is by using network scanning templates. If your company uses this method, you must select the default destination format in the XeroxScan connector properties.
Note: The default destination format pertains to the FaxNumber metadata field in the network scanning template. The FaxNumber field is required when you use network scanning templates to send faxes. (If your company sends faxes using the Network Fax configuration on the Xerox MFD, the default destination format does not apply.)
About XeroxScan Connector
Upland AccuRoute Server, Fax and XeroxScan Connector
Adding a XeroxScan Connector
Configuring Xerox Connector Defaults
About XeroxScan Connector Network Scanning Templates
Adding a XeroxScan Connector Repository
