DMS Routing Sheet Variables Lists
The following table lists the DMS variables that are available for Routing Sheets. For a list of other variables that can be used in Routing Sheets, see List of template variables (in alphabetical order).
Note: A recipient template variable to be used on the Routing sheet must look like: %DMS_xxxx.1% for the xxxx template variable of the first DMS recipient and %DMS_yyyy.2% for the yyyy template variable of the second DMS recipient and so on.
Additionally, all DMS Custom fields (that you can view in a default document profile dialog in a DMS Connector's admin extension) are also published in the Routing Sheet using the following naming scheme.
  •  %DMS_CF_InternalFieldName.1%
  •  %DMS_CF_InternalDMSFieldName_DISPLAY.1%
Variable
Description
Supported DMS
%DMS_MD_DOCUMENT_ID.1%
The unique internal DMS ID of the document
  • WorkSite
  • iManage
  • DM
  • WorldOX
  • FileShare
  • MyFolder
  • DocsOpen
  • Documentum
%DMS_MD_DOCUMENT_NAME.1%
Document name or title. For example: Quarterly Report
  • WorkSite
  • iManage
  • DM
  • WorldOX
  • FileShare
  • MyFolder
  • DocsOpen
  • Documentum
%DMS_MD_DOCUMENT_FRIENDLY_NAME.1%
The friendly name of the document which usually consists of the title and document’s number
  • WorkSite
  • iManage
  • DM
  • WorldOX
  • FileShare
  • MyFolder
  • DocsOpen
  • Documentum
%DMS_MD_DOCUMENT_NUMBER.1%
Internal unique DMS document number
  • WorkSite
  • iManage
  • DM
  • DocsOpen
%DMS_MD_DOCUMENT_COMMENTS.1%
Comment for the document
  • WorkSite
  • iManage
  • DM
  • WorldOX
  • DocsOpen
  • Documentum
%DMS_MD_DOCUMENT_VERSION.1%
Version number for the document
  • WorkSite
  • iManage
  • DM
  • DocsOpen
%DMS_MD_DOCUMENT_LIBRARY.1%
Name of the library where the document is being routed to
  • WorkSite
  • iManage
  • DM
  • Documentum
%DMS_MD_DOCUMENT_FOLDERID.1%
Unique internal DMS ID of the document’s folder
  • WorkSite
  • iManage
  • DM
  • Documentum
%DMS_MD_DOCUMENT_FOLDERID_DISPLAY.1%
Name of the DMS folder as shown in DMS Client
  • WorkSite
  • iManage
  • DM
%DMS_MD_DOCUMENT_CLIENT.1%
Client ID field of the document’s profile
  • WorkSite
  • iManage
  • DM
  • DocsOpen
%DMS_MD_DOCUMENT_CLIENT_DISPLAY.1%
Full display name of the Client's field
  • WorkSite
  • iManage
  • DM
  • DocsOpen
%DMS_MD_DOCUMENT_MATTER.1%
Matter ID field of the document’s profile
  • WorkSite
  • iManage
  • DM
  • DocsOpen
%DMS_MD_DOCUMENT_MATTER_DISPLAY.1%
Full display name of the Matter's field
  • WorkSite
  • iManage
  • DM
  • DocsOpen
% DMS_MD_DOCUMENT_CLASS.1%
Document's Class ID field
  • WorkSite
  • iManage
  • DM
  • WorldOX
%DMS_MD_DOCUMENT_CLASS_DISPLAY.1%
Full display name of the document's Class field
  • WorkSite
  • iManage
  • DM
%DMS_MD_DOCUMENT_SUBCLASS.1%
  • WorkSite
  • iManage
%DMS_MD_DOCUMENT_SUBCLASS_DISPLAY.1%
Full display name of the document's Subclass field
  • WorkSite
  • iManage
%DMS_MD_DOCUMENT_AUTHOR.1%
Document's Author ID field
  • WorkSite
  • iManage
  • DM
  • WorldOX
  • DocsOpen
  • Documentum
%DMS_MD_DOCUMENT_AUTHOR_DISPLAY.1%
Full display name of the document's Author field
  • WorkSite
  • iManage
  • DM
  • DocsOpen
%DMS_MD_DOCUMENT_TYPE.1%
Document's Type ID field
  • WorkSite
  • iManage
  • DM
  • Documentum
% DMS_MD_DOCUMENT_TYPE_DISPLAY.1%
Document type's full display name
  • WorkSite
  • iManage
  • DM
About Custom Variables
Creating Custom Variables
Exchange Database Variables List
Notes Address Book Variables List
Recipients and Distribution Lists Variables
Top Line Format Variables List
Template Variables List
