Managing Fax Properties
By modifying the properties of the Telco connector, you can configure options for fax channels.
Modem properties
Options for modem properties include:
  • Detecting channels on a fax board
  • Using custom dialing rules
  • Modifying the top line, or header, of outbound faxes
Channels
Options for channels include:
  • Selecting the run mode for a channel as normal, send only, or receive only
  • Specifying the CSI/TSI value for a channel
  • Configuring a channels' receive properties to capture DTMF digits, use DNIS, use a DID lookup mask, and accept partially received faxes
  • Setting the number of seconds for timeout, number of busy retry attempts, interval between busy retry attempts, and the number of minutes the channel should wait for a dial tone.
  • Using a dialing rule and specifying the characters that the channel allows in dialing strings.
  • Configuring the channel to resend partial faxes
  • Configure the channel not to send faxes to a fax number that is being dialed by another channel
Tip: Using the modem status feature, you can check the status of all channels associated with the Telco connector.
Telco connector properties
You can also modify the following Telco connector properties.
  • Change the connector name
  • Enable or disable the connector
  • Modify the connector profile
  • Modify the path to the Telco share directory
About Telco Connector
About Modem Server
Modem Server Telco Connector Benefits
Adding a Telco Connector
