Adding Dialing Rules Access and Billing Codes
You can add the access and billing codes to a dialing rule when creating or modifying a rule.
Open the Dialing Rule Properties dialog box.
Go to the dialing section.
In the Prefix and Suffix boxes, enter the access codes and billing codes variables as needed. For information on the variables, see Access codes and billing codes variables.
For instructions on creating dialing rules, see Creating a dialing rule. For instructions on modifying dialing rules, see Viewing and modifying the dialing rule.
Dialing rule with access and billing codes example
The following example shows a dialing rule properties after it has been created/modified to include the access code in the dialing prefix and two billing codes in the dialing suffix.
Using Dialing Rules Access and Billing Codes
