Modifying Server Profile
You can modify the Server profile by using the Properties page. When you complete this procedure, the server will begin processing messages by the new settings. These settings are overridden by the settings associated with a connector profile or user profile.
To modify the Server profile
  2. On the Server Administrator tree, right-click the server name.
  3. Click Properties from the drop-down menu. The Properties page opens.
  4. Click Settings.
  5. In the Manage Server Profile section, click Configure. The Server Profile Properties page opens.
  6. Click Access Code option to add or remove access codes from the profile.
  7. Click Billing Code option to modify the default billing code for the profile.
  8. Click OK to save your changes.
About Server Profile Types
Adding Dialing Rules Access and Billing Codes
Using Dialing Rules Access and Billing Codes
