About Server Profile Types
Profiles allow you to set defaults for inbound and outbound messages on the
Type of profiles
The server supports the following profiles.
Server-level profile
The order of precedence for profiles is as follows:
The settings associated with a user profile override all other profiles.
The settings associated with a connector-level profile can override the server-level profile.
You can specify in the profile whether you want a setting to override the server-level profile. -
The server-level profile cannot override any other settings.
More about the Server Profile
The server profile has the following settings that you can customize to meet your document workflow requirements.
You can specify the default access code for outbound messages submitted to the server.
Note: This access code can be applied to an outbound message only when the sender doesn't provide one.
This applies to the outbound message in two scenarios. In the first scenario, the sender submits a one-off message to the server. With a one-off message, the user does not have a way to provide an access code. In the second scenario, you have required the sender to provide an access code, but the sender did not provide one. When this happens, the server applies the default access code so that the outbound message does not fail.
You can specify the default billing code for outbound messages submitted to the server.
Note: This billing code can be applied to an outbound message only when the sender does not provide one.
This applies to the outbound message in two scenarios. In the first scenario, the sender submits a one-off message to the server. With a one-off message, the user doesn't have a way to provide a billing code. In the second scenario, you have required the sender to provide a billing code, but the sender did not provide one. When this happens, the server applies the default billing code so that the outbound message does not fail.
You can specify the default cover page template for use with outbound messages submitted to the server.
Note: The cover page template is used only when the sender does not select one.
You can set the value of a variable such that when the variable is used in cover page templates for outbound messages submitted to the server, the variable is populated with the value you specify.
You can allow all users to request fax preview when sending a fax message.
You can specify additional recipients who will receive notification messages for all outbound messages submitted to the server. Recipients can include email recipients, folders, and printers.
You can specify additional recipients who receive a copy of all outbound messages submitted to the server. Recipients can include email recipients, folders, and printers. You can optionally specify whether the message should include the original attachments to the message.
Adding Dialing Rules Access and Billing Codes
Using Dialing Rules Access and Billing Codes
