Using WebApps Queue Route
The WebApps Queue is an application that processes scanned documents which are routed to predefined queues as jobs. The queues are preconfigured in the Server Administrator where the Administrator assigns access rights and permissions to predefined user groups.
The WebApps Queue displays jobs awaiting user interaction for processing and delivery to a specific destination; for example, email, fax, printer, or archive.
With the Route action, Queue users can route jobs to specific recipients, include additional data like sender name, company name and email address. In addition, the queue user can route the entire document or specific pages and add comments if necessary.
Note: WebApps Queue Route supports both the server’s standard and Outlook’s Address Books.
Using WebApps Queue Route, users can route jobs to an email, fax machine, or printer.
Additional features enable users to:
  • Edit and annotate jobs before routing them.
  • Route and re-route single jobs.
  • Reassign jobs to other queues.
Routing documents
To route documents
  1. Open WebApps from your browser.
  2. Select Queue.
  3. Select a document to route and review.
  4. Select Route on the Queue toolbar.
See the Queue toolbar example below.
The Route Documents dialog box appears.
  1. Specify recipients in the Recipients box, for example, username@company.com.
  2. Use the default All or specify pages to route, for example, 1-5, 8, 10 if not all pages are to be routed in the Route Specific Pages box.
The following error message is displayed if page numbers are specified in a descending order when using the Route Specific Pages field.
  • An invalid page number was specified.
Page numbering must be specified in ascending order. See examples below.
  • In a range, for example, 1-5
  • Separated by commas, for example, 6,9,15
  • Or A combination of both formats, for example, 20-25, 30, 47, 52
  1. Specify comments in the Comments box.
  2. Specify name and company in the appropriate boxes.
Note: Contact your Administrator for the appropriate name and company values to be used in the fields if not known. These fields will only appear if they are required by your workflow. The following error message will appear if the fields are required and you did not provide the information.
See the error messages example below.
  1. Select Route and repeat steps 3-9 as needed.
Using WebApps Queue Redaction
Using WebApps Queue Thumbnail Page Management
