8.17.52015-05-05
About Related Programs and Services
Services are programs that run in the background and automatically perform tasks that often do not require any user interaction. With the exception of PlanetPress Workflow Configuration, all the programs used by PlanetPress Workflow are run as service applications. PlanetPress Workflow can thus use them as required without the need for any user interaction.
Although you can manually start and stop any service running on your computer, most of the basic services used by the system are started and stopped automatically. In the case of PlanetPress Workflow and their related services, you typically use a command included in your PlanetPress Workflow Configuration program to start and stop most services. Opening and closing your PlanetPress Workflow Configuration program has no effect on these services.
Available Input Services
Input services are used to pull in data files. The input services used by PlanetPress Workfloware:
Available Output Services
Output services are used to output jobs. The output services used by PlanetPress Workfloware:
Services must use an account to be granted the permission to use the system’s resources and objects. This information is included in the service's configuration and most services use the Local System Account, which is granted access to all the system’s resources. All input and output services used by PlanetPress Workflowrun under the same account. For more information on services and system permissions, refer to Windows documentation. For more information on how to configure the account used by the services, see PlanetPress Workflow Service Logon.
The PlanetPress Suite Service Console, included in the PlanetPress Suite Workflow Tools Configuration program, can be used to monitor, start and stop PlanetPress Workflow services (see About Processes, Users and Configurations and "PlanetPress Suite Service Console" (page n)).
