Processing Overtime: Custom Day / Holiday Rules
The overtime processing option accurately records the overtime worked, ensuring it is quantified and recorded correctly, as well as adheres to compliance with industrial boards for fair employee compensation and company protection. When configuring the system, administrators define how the overtime hours worked are configured. The overtime hours worked are defined as the hours that exceed the default hours already assigned per week for work. After the Enable Overtime Policy check box is selected (Setup > Timesheet > Timesheet Templates > Timesheet Template Edit > Options tab), the overtime policy can be defined.
Note:
  • Custom overtime rules work in conjunction with the Daily, Weekly and Bi-Weekly rules. If an Overtime rule is set only for the Custom tab, then the system will not apply the rule to the time entries.
  • At least one Overtime rule must be set for the Daily, Weekly or Bi-Weekly tab for the custom rule to be applied.
  • Overtime rules are applied in a specific order. For more information, see Processing Overtime: Rule Precedence.
  • If multiple overtime rules are set for the Custom tab, then the precedence for processing overtime is Custom>Holiday>Monday>Tuesday>... <Sunday>.
Custom Day Accumulation Rules Tabs
The following settings are available on the Custom Day Accumulation Rules sub-tabs:
  1. Add to overtime after [x] hour(s) worked: Determines the number of payable hours after which overtime starts to accumulate.
  2. Add to double overtime after [x] hour(s) worked: Determines the number of payable hours after which double overtime starts to accumulate.
  3. Include <No Time>/<Remaining Time>/<Remaining Time including Overtime>/<Remaining Time including Double Overtime>/<Total Time> from previous rule as regular time when processing this rule: Determines how many hours from the time entry are taken from the previous rule when processing the current rule.
    1. No Time: Does not include any time from this day in the accumulation rule.
    2. Remaining Time: Includes the remaining payable time in the accumulation rule, and excludes any overtime or double overtime hours.
    3. Remaining Time including Overtime: Includes the remaining payable time including my overtime hours in the accumulation rule, and excludes any double overtime hours.
    4. Remaining Time including Double Overtime: Includes the remaining payable time including double overtime hours in the accumulation rule, and excludes any overtime hours.
    5. Total Time: Includes the all payable time in the accumulation rule.
  4. Include overtime from previous rule as overtime when processing this rule: Specifies whether the overtime accumulated from the previous rule should be added to the overtime of the current rule.
  5. Include double overtime from previous rule as double overtime when processing this rule: Specifies whether the double overtime accumulated from the previous rule should be added to the double overtime of the current rule.
Custom Holiday Accumulation Rules Tab
The following settings are available on the Custom Holiday Accumulation Rules sub-tab:
