Configuring a Language Property and Prompt
You can configure a language property and prompt so that users at a device can select a language as their OCR final format. In addition, directives can be created to route and verify a document's final format by configuring the Web Client. Directives can be tested and verified at a device for each supported language.
Note: Repeat the entire procedure for each supported language.
About OCR Language Support
Enabling and Disabling OCR Supported Languages
Testing Compose of an Asian Language
About PDF/A Document Final Format
