Enabling and Disabling OCR Supported Languages
By default, the English language is enabled for OCR processes at the server level. You can enable any other language that is supported by the server, if required.
To enable or disable OCR supported languages
    • On the Start menu, click Upland AccuRoute > Upland AccuRoute Server Administrator.
  2. On the console, expand the Server Administrator tree and navigate to Components. The details pane lists the components in your environment.
  3. Double-click the Compose component. The Properties for Compose dialog box appears.
  4. Click the OCR tab.
  5. Click Advanced. The OCR Properties dialog box appears.
  6. Click the Languages tab.
  7. Select or clear to enable or disable a language.
  8. Click OK to save your changes.
About OCR Language Support
Configuring a Language Property and Prompt
Testing Compose of an Asian Language
About PDF/A Document Final Format
