About FileBound Connector
The FileBound connector is integrated with Upland FileBound. This connector supports all standard DMS connector features, including Default Profiles, Distributions, and RuleSets. For example, users can scan documents to FileBound from an MFP device using either a Routing Sheet or a Personal Distribution that identifies FileBound as the recipient. For documents processed using OCR, the system will automatically store the OCR text in the FileBound document's FullText property for search and indexing.
Note: The FileBound connector requires a DMS license.
Installation and Configuration
Before adding and configuring the FileBound connector, you must already have a FileBound project (with fields, separators, and dividers) configured.
Creating and configuring the FileBound connector
To create and configure the FileBound connector on the server
  1. In the Server Administrator, right-click Connectors.
  2. Select New AccuRoute connector > FileBound. The Create New FileBound DMS Connector wizard appears..
  3. Use the default server address: Run on the Message Server or specify a Remoter Server address in the box.
  4. Select Next.
  5. Use the default name or specify a new name for the FileBound connector.
  6. Select Next.
  7. Select Finish.
  8. Type a Rest EndPoint URL (FileBound URL address) and the associated username and password in the appropriate boxes.
Note: The FileBound Rest Endpoint URL comes from your FileBound instance.
  1. Select OK.
Delivering Messages to FileBound
