About Distributions
                                            A Distribution is a defined group of one or multiple recipients and associated Routing Rules. With Distributions, you can access and view your personal and subscribed distributions.
The My Distributions tile lists your Personal and Public distributions created  in
View or edit distribution properties.
Select the distribution and use the Properties button in the toolbar to view and edit the properties.
Delete a distribution.
Select the distribution and use the Delete button in the toolbar to delete the distribution.
The Subscribed Distributions tile lists the Public Distributions of other users that you are subscribed to. With Subscribed Distributions, you can perform the following tasks.
See instructions above.
Note: Distributions are available on the Embedded Device Client display panel. Personal Distributions require authentication. By default, Public Distributions do not. With either, you can use a single MFP button to instruct the server to send your document to the recipients in your selected distribution.
| My Distributions Legend | Description |
| 1. Toolbar |
        Use the toolbar to:
| 2. My Distributions grid and columns |
        View the following parameters.
 Note: Use the Up or Down arrow in the column header to sort items in ascending or descending order.  |
| 3. Page navigation toolbar | Go to and view first, previous, next or last page. |
| 4. Refresh icon |
        Use to refresh the grid and get the latest distributions.  |
The Subscribed Distribution grid is similar to My Distributions.
The grid shows the following parameters.
Owner - Subscribed Distribution owner's email address.
Title - Subscribed Distribution name
Created - Date and time stamp
Last used - Date and time stamp
Recipients - Included in the distribution
Note: The Delete button is not available for subscribed distributions. You cannot delete subscribed distributions. See the My Distributions legend above for more information.
Creating a Personal Distribution
Creating a Favorite Distribution
