Confluence connector release notes
The respective releases of the Confluence connector feature the following enhancements. For more information about the connector, see About the Confluence Connector.
Confluence Connector 3.3.2.0
System Enhancements
| Feature | Description |
| Filtering enhancements |
Custom filters for the Confluence connector now uses improved JSON string logic to include or exclude Confluence spaces and pages in crawls. For more information, see Deploy your Confluence connector. For more information on configuring custom filters, see Filter content from a Content Source in the Connectivity Hub documentation. |
Fixed issues
There are no fixed issues in this release.
Confluence Connector 3.3.1.0
System Enhancements
There are no system enhancements in this release.
Fixed issues
The Confluence connector was failing in Test Bench, with a "the added or subtracted value results in a unrepresentable datetime" error, when the user's system locale was different from the default Confluence locale. (BAI-17918)
Confluence Connector 3.3.0.0
System Enhancements
| Configuration enhancements | The Confluence connector web.config file now includes parameters for configuring retry attempts and messages when timeout errors occur during crawl operations. For more information, see configure Your Confluence Cloud Connector Using Web.config. |
Fixed issues
Confluence Connector 3.2.0.0
System Enhancements
| Index filtering enhancements | The Confluence connector now supports filtering by the space type (personal or global) in Confluence. Admins now have the option of indexing only the selected Confluence space from the Content Filters tab when configuring their content source Content Sources do the following: Receive data from the Source System via the Connection, Filter the data it receives, Provide the results to the Target, Define the specific search index that contains the content you wish to index (and later search). in Connectivity Hub. For more information, see How to Set Up a Content Source in the Connectivity Hub documentation. |
| Attachment enhancements | When indexing a Confluence page that has attachments, the Confluence connector will now index attachments as part of the page item. When a user searches for a keyword that is included in an attachment, the connector will now return the specific attachment as well as the Confluence page that it is associated with. |
| Search user enhancements |
The Confluence connector can now use the |
| ACL enhancements | The Confluence connector will now preserve the security and access levels that exist on the Confluence page, including ACL permissions for users that have access to parent pages and spaces. |
| BA Insight connector SDK upgrade | The Confluence connector has been upgraded to use the BA Insight connector SDK v3.0.0.12. |
Fixed issues
Confluence Connector 3.1.0.0
System Enhancements
| Confluence Data Center Edition support | The Confluence Connector now supports the Confluence Data Center edition. The Confluence connector uses OAuth Specifies a process for resource owners to authorize third-party access to their server resources without providing credentials. 2.0 to authenticate against Confluence. As a result, the installation steps have been updated and are available here: How to Set Up and Configure the Confluence Cloud Connector. |
| Confluence Standard Edition support | Confluence Standard Edition is no longer supported in this release of the Confluence Connector. If you want to upgrade to Confluence Connector 3.1.0.0, you must use the Confluence Cloud or the Confluence Data Center Edition. |
| Metadata Provides context with details such as the source, type, owner, and relationships to other data sets. Metadata provides details around the item being crawled by Connectivity Hub. enhancements |
The following enhancements have been made to the returned metadata for the Confluence connector:
Fixed issues
| Issue | Description |
| BAI-15536 | On the OAuth page for the confluence connector, the images were broken. |
| BAI-15620 | The Client ID field was not specified as mandatory when using Confluence OnPrem with an OAuth connection Connection defines the how Connectivity Hub connects to your Source System (which contains your documents, graphics, etc.,). Your Connection includes identifying elements such as: URL of the BA Insight web service connector you are using, (File Share connector, SharePoint Online connector, etc.), Authentication mode, User Accounts and Credentials, Database information (for database connectors). |
Confluence Connector 3.0.3.0
System Enhancements
Added handling for response JSON objects with missing fields or values.
Addressed vulnerabilities detected in dependency libraries scan.
Resolved Issues
| Issue | Summary |
| BAI-12081 | Crawl shows "Failed" with the error message "Cannot perform runtime binding on a null reference." |
| BAI-12602 | WhiteSource detected vulnerabilities in connector dependencies. |
