Syntax Definitions
The following table summarizes the functions available within Engage. Detailed breakdowns with examples are available in each function's dedicated article.
Function Category Summary
ABS
Maths Function
Returns the Absolute Value of a number.
AFTER
Cross-table
Checks the source query against the target query and returns True if any of the records in the source query came after those in the target query.
AGE
Date Function
Returns the age in years from the value supplied to the current system date.
AGEAT
Date Function
Returns the age in years from the value supplied in the first argument to the value supplied in the second argument.
ANNIVERSARY_DATE
Date Function
Returns the date of an anniversary.
ANNIVERSARY_DAYSTO
Date Function
Returns the number of days to an anniversary.
AREA_LABEL
Geographic
This function will extract the area label from a postcode in standard UK format.
AVERAGE
Cross-table
Takes all the child records that match the optional filter query and sums the values for each parent record. Then divides the sum by the number of child records for the parent that match the criteria.
AVERAGE_BYINDEX
Cross-table
Takes all the child records for each parent that match the optional filter criteria and fall within the specified index and returns the average for each parent record.
AVGDIFF
Cross-table
Returns a number that represents the average difference between each of a child records of the parent.
BANDINDEX
Objects
This function will return a number that indicates which element of a band each record falls into.
BEFORE
Cross-table
Takes the child records for each parent and sorts them by the field specified in the fieldName parameter.
CampaignSelection
Campaign Function
Specialised function to allow querying on standard campaign history and response tables.
CATEGORISE
Text Function
Turns a delimited list of data values into a categorised data banding.
CEILING
Maths Function
Returns the value from a numeric field rounded up to the next whole number.
CHR
Query Domain
Converts the value supplied into the equivalent ASCII character for that number.
CODE
Text Function
Returns the ASCII character code for the first character of the string supplied.
CONCATENATE
Text Function
Joins several text values together into a single text value.
CONVERT
Data Conversion
Converts one datatype to another.
COUNT Cross-table Returns the number of child records for each parent. The optional filter query restricts the child records to be included in the calculation.
COUNT_BYINDEX
Cross-table
Returns the number of child records for each parent that match the optional filter criteria, and fall within the specified index.
COUNTDISTINCT
Cross-table
Returns the number of distinct values in a field on the child table for each parent record.
CURRENT_TIMESTAMP
Constants
Returns the current date and time.
DATEADD
Date Function
Adds a time interval to the input date.
DATEPART
Date Function
Returns just the date part from a value that includes the date and time.
DAY
Date Function
Returns the day component of the date supplied. Any leading zeros are removed.
DAYOFMONTH
Date Function
Returns the day in a month for the date supplied, from 1 to 31.
DAYOFWEEK
Date Function
Returns the day of week component of the date supplied. Any leading zeros are removed.
DAYOFYEAR
Date Function
Returns the day of the year for the date supplied. Any leading zeros are removed.
DAYSTO
Date Function
Returns the number of whole days between two given dates.
DECODE
Conditions
Decodes values within a discrete field to an alternative set of values.
DISTANCE
Geographic
The geographic field to extract the area section from.
DISTRICTLABEL
Geographic
This function will extract the district label from a postcode in standard UK format.
EXP
Maths Function
Returns e raised to the power of the value in a numeric field.
FIRST
Cross-table
For each parent record, returns the value from the first child record. The child records are looked at in natural unsorted order.
FirstDistinct
Query Domain
When used within a query the function produces a recordset that contains only one record for each unique value of the argument.
FLAG
Cross-table
Flags the first occurrence of a record that meets the criteria supplied in the filterQuery argument.
FLOOR
Maths Function
Returns the value from a numeric field rounded down to the next whole number.
FORMAT
Geographic
The format function allows the output format of a Geographic field to be changed into a number of different formats.
GeoSelection
Geographic
A specialised function that selects all the leads within a radius specified in metres of a central geographic point.
GETAREA
Geographic
This function returns the internal area number of standard UK postcode.
GETDISTRICT
Geographic
This function returns the internal area number of a standard UK postcode.
GETEASTING
Geographic
Returns the distance, in metres from the OSGB reference point, near the Scilly Isles, due east to a specified postcode.
GETISBA
Geographic
Returns the ISBA TV region as derived from the postcode.
GETNORTHING
Geographic
Returns the distance, in metres from the OSGB reference point, near the Scilly Isles, due north to a specified postcode.
GETSECTOR
Geographic
This function returns the internal sector number of a standard UK postcode.
HOUR
Date Function
This function returns just the hour from a date time field.
IF
Conditions
Checks whether the condition is true or false and returns the value specified in the true argument if the condition is met or in the false argument if it is not.
INDEX
Cross-table
Returns a number for each child record that indicates its index.
INDEXOF
Text Function
Returns the position of the first character that matches the specified string.
ISNULL Conditions Checks the value for a specified field and if the value is NULL it will replace the NULL value with the value supplied in the field name or constant value argument.
KEYVALUE
Text Function
Imports data from a key file.
LABEL
Text Function
Returns field label if present.
LARGEST
Maths Function
Returns the largest value from the supplied values.
LAST
Cross-table
Returns the value from the last child record for each parent record.
LASTDELETEDATE
Constants
Using the table name supplied the function returns a date and time that represents the last time that a delete action was carried out on the specified table.
LASTPRIMARYVALUE
Constants
Using the table name supplied the function returns the value of the primary key on the last record of the specified table.
LASTUPDATEDATE
Constants
Using the table name supplied the function returns the last date and time that the specified table was subject to an update or append of records.
LEFT
Text Function
Returns the number of characters specified from the left-hand end of a string.
LEN
Text Function
Returns the number of characters in the specified string.
LN
Maths Function
Returns the Natural Logarithm (base 2.71828) for the values in a numeric field.
LOG (Log10)
Maths Function
Returns the Common Logarithm (base 10) for the values in a numeric field.
LOWER
Text Function
Converts all the characters of the specified string into lower case.
MAXDIFF
Cross-table
For each parent, returns a number that represents the maximum difference between each of the child records.
MAXIMUM
Cross-table
Returns the maximum value of a field on the child table for each parent record.
MAXIMUM_BYINDEX
Cross-table
Takes all the child records for each parent that match the optional filter criteria and fall within the specified index and returns the maximum for each parent record.
MEDIAN
Cross-table
Returns the median value of the child records for each parent record.
MINDIFF
Cross-table
For each parent, returns a number that represents the minimum difference between each of the child records.
MINIMUM
Cross-table
Returns the minimum value of the field on the child table for each parent record.
MINIMUM_BYINDEX
Cross-table
Takes all the child records for each parent that match the optional filter criteria and fall within the specified index and returns the minimum for each parent record.
MINUTE
Date Function
This function returns just the minute from a date time field.
MODE
Cross-table
Return the most frequent value of a field.
ModelSelection
Model Function
A specialised function that selects leads from a model.
MONTH
Date Function
Returns just the month element of the date supplied.
MONTHSTO
Date Function
Returns the number of whole months between two given dates.
N_PER_TABLE
Cross-table
Allows N records to be selected from a table across a 1 to many join based on the value of a field at the many end.
NETWORKDAYS
Date Function
Returns the number of working days between two dates.
NOT
Query Domain
This function inverts the recordset that is created by the expression argument.
NTH_AFTER
Cross-table
Flags child records that are after records that meet the criteria given in the source query.
NTH_BEFORE
Cross-table
Flags child records that are before records that meet the criteria given in the source query.
OFFSET_VALUE
Cross-table
Retrieves a sibling value.
ONE_IN_N
Query Domain
When used within a query the function produces a recordset that contains a sample of records.
ONE_PER_TABLE
Query Domain
When used within a query the function produces a recordset that contains one record for each parent record defined by the relationship between the tables.
PENULTIMATEDELETEDATE
Constants
Using the table name supplied the function returns a date and time that represents the penultimate time that a delete action was carried out on the specified table.
PENULTIMATEPRIMARYVALUE
Constants
Using the table name supplied the function returns the value of the primary key on the last record of the specified table at the time of the penultimate update.
PENULTIMATEUPDATEDATE
Constants
Using the table name supplied the function returns the penultimate date and time that the specified table was subject to an update or append of records.
POWER
Maths Function
Raises the value in a numeric field to a specified power.
PROPER
Text Function
Uppercases the first letter of each separate word in the specified string.
QUARTER
Date Function
Returns the quarter value (1-4) from a date time field.
RAND
Maths Function
Returns a random number between 1 and the value specified.
RECENCY
Cross-table
Returns a number for each child record that indicates its recency.
RecordID (_URN)
Constants
Returns the Unique Record Number for each record.
REPLACE
Data Conversion
Returns a new string in which all occurrences of the match string are replaced by the replace string.
RIGHT
Text Function
Returns the number of characters specified from the right hand end of a string.
ROUND
Maths Function
Rounds the values in a numeric field.
SAMPLE_N
Query Domain
When used within a query the function produces a recordset of only a number of the records from the input recordset.
SAMPLE_P
Query Domain
When used within a query the function produces a recordset of only a percentage of the records from the input recordset.
SDEV
Cross-table
Returns a number that represents the standard deviation of a parents child records.
SDEV_BYINDEX
Cross-table
Returns a number that represents the standard deviation of a parents child records. However, only the number of records specified by the index parameter will be used.
SECOND
Date Function
This function returns just the second from a date time field.
SECTORLABEL
Geographic
This function will extract the sector label from a postcode in standard UK format.
SIGN
Maths Function
Returns -1 for negative values in a field, 0 for zero values and 1 for positive values.
SIZE_SELECTION
Query Domain
When used within a query the function produces a recordset of the specified number of records.
SMALLEST
Maths Function
Returns the smallest value from the supplied values.
SOUNDEX
Text Function
Soundex is a phonetic algorithm for indexing names by sound, as pronounced in English.
SQRT
Maths Function
Returns the square root of a value in a numeric field.
SQUARE
Maths Function
Returns the square of a value in a numeric field.
STAT_5TH_PERCENTILE
Field Statistics
This function returns the 5th percentile value for every record in a table.
STAT_95TH_PERCENTILE
Field Statistics
This function returns the 95th percentile value for every record in a table.
STAT_IQ_RANGE
Field Statistics
Returns the same value for every record in a table and allows the resultant summary statistic for a field to be compared against each individual value for the field.
STAT_MAXIMUM
Field Statistics
This function returns the maximum value for every record in a table.
STAT_MEAN
Field Statistics
This function returns the mean value for every record in a table.
STAT_MEDIAN
Field Statistics
This function returns the median value for every record in a table.
STAT_MINIMUM
Field Statistics
This function returns the minimum value for every record in a table.
STAT_MODE
Field Statistics
This function returns the mode value for every record in a table.
STAT_RECORD_COUNT
Field Statistics
This function returns the record count value for every record in a table.
STAT_SDEV
Field Statistics
This function returns the standard deviation value for every record in a table.
STAT_SUM
Field Statistics
This function returns the sum value for every record in a table.
STRIP
Text Function
Removes all spaces from a string.
SUBSTRING
Text Function
Returns a number of characters from the middle of a string.
SUM Cross-table Returns a number that represents the sum of a parents child records.
SUM_BYINDEX
Cross-table
A query string representing the domain of records to include.
TABLE
Query Domain
The function increases the flexibility of the query language by mimicking the results of rolling a selection.
TABLERANK Field Statistics The Tablerank function returns the rank of each record within a table, based on the specified numeric field. This will allow you to sort and filter your data before ranking it, to calculate and flag the top or bottom records for that value.
TagSelection
Campaign Function
Function to allow querying of Tags by name or id.
TagValueSelection
Selection Function
A specialised function that selects leads from tagged data.
TIMEPART
Date Function
Returns the time part from a datetime value.
TIMESTAMPADD
Date Function
Returns a new date value based on adding an interval to the date supplied.
TIMESTAMPDIFF Date Function Calculates the interval between two given dates. The interval timeframe can be changed depending on the fields need.
TOP_N
Query Domain
When used within a query the function produces a recordset that contains the top or bottom n records based on their values for a given numeric field.
TRACKFIELD
Object
This function is used to return the difference between the band index of the same record on different bands.
UNICHR
Text Function
The function returns the Unicode character for the numeric value supplied.
UNICODE
Text Function
The function returns the Unicode character code for the character value supplied.
UPPER
Text Function
Uppercases all the characters in the string supplied.
WEEK Date Function Returns the week number of the year (1-52) in which a date falls as a number, allowing transactions to be grouped and reported on by fiscal week number.
WEEKDAY
Date Function
Returns the day of the week for the date supplied.
YEAR
Date Function
Returns the year portion of the date supplied.
_URN (RecordID) Constants Returns the Unique Record Number for each record.
