About Document Action Log
Administrators can use the Document Action Log feature to record and log into an SQL table all the information related to document/record access by an Upland AccuRoute Web Client user. The SQL table is created by default in the Archive Database and is named ActionLog.
Historically, user access to documents via the Web Client was captured through the job activity logs associated with individual jobs. However, limitations with internal format of data storage meant that this data was not easily accessible. Now, with the Document Action Log feature, Administrators can use familiar reporting tools to monitor and report on user/document activity.
This is particularly useful to companies within the Healthcare environment where Administrators are routinely required to trace user access to a specific document or set of documents, as well as all the documents a specific user may have accessed, for HIPPA compliance reasons.
You can place the SQL table ActionLog in any location accessible by the server. The management of the schema should be done by the Server Administrator via normal SQL database table management. (In this sense, its management is similar to management of the Billing/CostRecovery table.)
Note: The ActionLog table is updated only when a user searches for or views configured Volume Lists with the Web Client. As the user selects (either implicitly or explicitly) a document contained in a Volume List, an entry is made in the ActionLog table.
About Volume Lists
Creating a Volume List
Adding Volume Lists Connector
Enabling Volume Lists Logging
Configuring Volume List Queue Properties
Configuring Volume List Restrictions
About Fax Hold and Release
