Adding Volume Lists Connector
You can add a connector for Volume Lists by using the Server Administrator > Connectors node.
To add a connector for Volume Lists
Click Start > All Programs > Upland AccuRoute > AccuRoute Server Administrator.
In the console tree, expand the AccuRoute Server Administrator and right-click Connectors.
Select New AccuRoute Connector for > Volume List. The Server Address page opens.
Click Next. The Display Name page opens.
Enter an appropriate name for the connector or keep the default Volume List on the Server.
Click Next. The Select Volume List page opens.
Select the Volume List where the documents should be routed to and stored.
Click Next. Configuration is now complete and the Congratulations page opens.
Click Finish. The connector now appears in the details pane.
Continue with the next procedure, Configuring Volume List Queue Properties.
Configuring Volume List Restrictions
