Enabling Volume Lists Logging
You can use document action logging to restrict what logging is generated based on a regular expression. Logging supports actions when an item is cancelled, modified, deleted, or moved for processing in the Server Administrator.
To enable logging
  1. Click Start > All Programs > Upland AccuRoute > AccuRoute Server Administrator.
  2. Expand the Server Administrator tree and right-click Volume Lists.
  3. Select Properties.
  4. On the Logging tab, select the Enable collection of document actions option.
  5. Click the Advanced button.
  6. Click the Insert button.
  7. Select the property that needs to be available in order for logging to be generated. Click OK.
  8. Click OK to complete the procedure.
If you are creating your own database, you will need to complete the following actions in order to capture the Recipient ID of the message.
  • Set up the action log table to have a column \\prLogDetails\prRecipientGUID NVARCHAR(MAX).
  • Define a Property Dictionary Item for RecipientGUID = prRecipientGUID.
  • Verify that the volume for ObjectArchive has RecipientGUID.selected in the indexing.
About Volume Lists
Creating a Volume List
Adding Volume Lists Connector
Configuring Volume List Queue Properties
Configuring Volume List Restrictions
About Document Action Log
About Fax Hold and Release
