Before You Start
Upland Analytics allows you to create insightful dashboards and data visualizations that allow the discovery of hidden insights in your data easily.
To create a useful, easily understood report, it helps to make a plan. Some of the things you might want to consider before you get started are:
What do you want your Upland Analytics Object to look like?
The use of a variety of charts, widgets, pivot tables and view components allow for the creation of insightful reports and dashboards
The Display Format of your Upland Analytics Object is a very useful means of presenting information so that changes and patterns can be quickly recognized.
Available Display Formats within Upland Analytics are:
Report
The Report is a simple spreadsheet-like presentation of data. |
Pivot Table
A Pivot Table is an interactive way to quickly summarize large amounts of data. You can use a Pivot Table to analyze numerical data in detail. |
Bar Graph
A Bar Graph displays series as sets of horizontal bars and is used to show a comparison among different items, or show a comparison of items over time. |
Stacked-Bar Graph
A Stacked-Bar Graph (or stacked-bar chart) is a chart that uses bars to show comparisons between categories of data, but with the ability to break down and compare parts of a whole. Each bar in the chart represents a whole, and segments in the chart represent different parts or categories of that whole. |
Line Graph
A Line Graph displays a series as a set of points connected by a single line. Line charts are used to representing large amounts of data that occur over a continuous period of time and can be used to show many different categories of data. |
Pie Graph
A Pie Graph displays data as a proportion of the whole. Pie charts are most commonly used to make comparisons between groups. |
Radial Gauge
A Radial Gauge chart has a circular arc and displays a single value that measures progress toward a goal/KPI. |
Scatter Graph
A Scatter Graph displays a series as a set of points. Scatter Graphs can be used when there are many different data points, and you want to highlight similarities in the data set. |
Bubble Graph
A Bubble Graph is similar to a Scatter Graph in that it can show distribution or relationship. |
Motion Graph
A Motion Graph is a dynamic display that is used to explore several data fields over time.
Heatmap
A Heatmap shows the relationship between two items and provides rating information, such as high to low or poor to excellent. |
Radar Graph
A Radar Graph displays a series as a circular line or area. |
Area Graph
An Area Graph is basically a line chart, but the space between the x-axis and the line is filled with a color or pattern. It is useful for showing part-to-whole relations. |
Waterfall
A waterfall chart is a type of bar graph, similar to a Stacked-Bar chart except that bars don't overlap and the origin of each bar starts where the previous bar ended, allowing negative values to be readily depicted.  |
Sunburst
The Sunburst graph shows hierarchy through a series of rings, that are sliced for each category node. Each ring corresponds to a level in the hierarchy, with the central circle representing the root node and the hierarchy moving outwards from it.
KPIs
A Key Performance Indicator (KPI) is a measurable value that demonstrates how effectively a company is achieving key business objectives. |
Gantt
A Gantt chart is a type of bar chart that illustrates a project schedule. This chart lists the tasks to be performed on the vertical axis, and time intervals on the horizontal axis.  |
Control
Use control charts to filter out the probable noise (inherent variation or common cause) from the potential signals (nonrandom variation or special cause). From this, you know when and where to take action on a process.  |
Box Plot
A box plot chart presents information from a five-number summary. It does not show a distribution, but is especially useful for indicating whether a distribution is skewed and whether there are potential unusual observations (outliers) in the data set. Box plots are also very useful when large numbers of observations are involved and when two or more data sets are being compared.
Box plots are ideal for comparing distributions because the center, spread, and overall range are immediately apparent.
Pareto
A Pareto chart contains both bars and a line graph, where individual values are represented in descending order by bars, and the cumulative total is represented by the line.  |
For more information on the Display Formats click
here.
Do you need to create your own calculations?
Upland Analytics Custom Fields tab allows you to build your own formula or Function using an easy to use formula engine, offering extensive mathematical and statistical functions.
Should the data be filtered?
Use filters to pare down your report until it only shows the data that you want.
How are you going to deliver your report?
Upland Analytics Dashboard capability allows you to combine multiple reports into a single dashboard and drill down on the data. For more information on dashboards click here.
You may also export or print reports or dashboards for offline access or presentations. For more information click here.
