Prerequisites: Other Backends
In addition to the information in the table below.
See the topic of the backend you are using for additional information about its Prerequisites.
About
The backends listed under Connect SmartHub to Other Backends are domain-specific backends.
These backends have specific characteristics.
Supported and Unsupported functions are listed here:
Supported Functions include, but are not limited to:
  • Pagination
  • Sorting
Unsupported Functions include:
  • Query translation
  • Refiners
For these reasons, Domain-specific backends are typically used with content-by-search components.
Note: Be sure to install all the prerequisites listed for your SmartHub and backend instance.
Any issues experienced by BA Insight clients during installation are typically traced to a failure to meet the required prerequisites.
Installation Prerequisite Checklist
Important!
If you have already installed BA Insight SmartHub and a backend, skip to the "Search Engine" portion of the Requirements table below
Requirement
Description
Completed
SmartHub Server
Operating System Microsoft Windows Server
  • 2012 and 2012 R2: 64-bit
  • 2016
  • 2019
  • 2022
  • (Complete)
Windows Roles and Features Must have Web Server(IIS) role enabled with the following Roles and Features selected:
  • Common HTTP Features
  • Health and Diagnostics
  • Performance
  • Security
  • Application Development
    • .NET 3.5
    • .NET 4.6
      • ISAPI Extensions
      • ISAPI Filters
      • WCF Services
        • HTTP Activation
  • .NET Framework 4.6 Features
    • WCF Services
      • HTTP Activation
  • (Complete)
.NET Framework
  • .NET Framework v4.7.2 required for Windows Server versions: 2012, 2016, 2019
  • .NET Framework v4.8 required for Windows Server 2022 (included with Windows and used automatically, by default)
  • (Complete)
Service Account (domain\user)
Local or network service account used to run the SmartHub Application pool in IIS
  • Must be in the format domain\user
  • Requires read/write access to the directory SmartHub is installed in.
Account credentials: (domain\user)
Installation Account (domain\user)
Account used to install SmartHub
  • Must be local admin on machine
Supported Web Browsers
  • Google Chrome
  • Chromium-powered Edge
  • Other browsers unsupported*
*Unsupported Web Browsers
Other web browsers may work with SmartHub, such as:
  • Microsoft Edge (legacy)
    • To check your version of Edge, go here.
  • Firefox
  • Safari
These browsers are not officially supported by BA Insight.
Analytics Index
Elasticsearch v7.6
Secured or non-secured Elastic configurations supported.
Note: The Elasticsearch index used for the SmartHub data does not have to be the same instance use for the search index (backend).
Note: Elasticsearch requires Java JDK. Elasticsearch v7.x and later bundles Java with the software (OpenJDK). A separate Java download/install is NOT required.
For assistance installing a single-node instance of elastic, see: How to Install Elasticsearch for Analytics
Elasticsearch URL:
Elasticsearch Username:
Elasticsearch Password:
Kibana v7.6
Kibana must be configured to use the above Elasticsearch index.
Supports secured or non-secured Kibana configurations
For assistance installing Kibana and running as a Windows service, see: How to Install Kibana for Analytics
Kibana URL:
Kibana Username:
Kibana Password:
NLQ Services (Optional)
  • LUIS (v2 API)
  • RASA v1.9
  • Amazon Lex
Only one NLQ service should be configured.
Supported NLQ/AI Engines:
For more information see:
Service Endpoint:
Service Key (LUIS only):
Search Engine (backend)
Bing News
  • Bing API Access Key
    • The subscription key that you received when you signed up for this service.
See your specific backend topic for complete information, including limitations, requirements, and configuration settings.
Bing Search
Egnyte Backend
  • Egnyte Domain
    • The Egnyte domain you want to search.
      • For example: myegnyteapp.egnyte.com
  • Egnyte Impersonation Property
    • The name of a property that will be added in the client context properties that will hold the username of the user to be impersonated (this will be done with a script, in a Query Scripting Processor stage, later).
  • Access Token
    • Generated during the configuration of the Egnyte backend.
    • See the Egnyte backend topic for details.
Expertise Backend
  • Expertise backend is fully integrated into SmartHub
iManage Backend
  • Network service account
A service account can only be used with a single SmartHub instance at any one time.
Microsoft Academic Knowledge
  • Academic API Subscription Key:
Microsoft Search Drive Items
  • Microsoft Graph API permissions
    • See the specific documentation topic of your Microsoft backend for details.
Microsoft Search Events
Microsoft Search External Items
Microsoft Search Message
NetDocuments Backend
  • User Access to the NetDocuments cabinets being searched
    • SmartHub requires the Admin user to have the following permissions:
      • Permission to retrieve cabinets
      • Permission to READ other user's details.
  • Cabinets
    • The cabinets you access must be in the same repository.
    • To search cabinets from multiple repositories you must configure a separate SmartHub NetDocs backend for each repository
PubMed Backend
  • (Backend) API Key
    • When you register a new PubMed account, you are given the option to create a key.
RightFind Backend
  • RightFind Domain
    • The RightFind domain you want to search. For example: www.myrightfinddomain.rightfind.com
  • User Email
    • The email of the user account that has access to all items
  • Password
    • The password for the email above.
  • Access Token
    • The access token obtained after authenticating.
    • For detailed instructions, see the RightFind backend topic.
  • Refresh Token
    • The refresh token obtained after authenticating, used to refresh the access token when it expires.
Network Requirements
DNS entry for SmartHub site
This can be either an internal, or an external (public) DNS entry.
Entry can point to VIP / F5 / Load Balancer / other network device.
Requests should be routed to IIS on the SmartHub server over the chosen ports.
DNS name / URL for SmartHub:
SSL Certificate If running SmartHub over SSL (recommended), a signed SSL certificate for that DNS name (or appropriate wildcard cert) is required.
Certificate name:
Passphrase (if required):
Internal Network Connectivity
The SmartHub server must have network connectivity to the following:
  • Analytics Index
  • Search Index
  • RASA NLQ Service (optional)
Verified:
  • Elasticsearch service (see Analytics Index, above)
  • Kibana service (see Analytics Index, above)
  • Search Index
External Network Connectivity Network connectivity from the SmartHub server to the following Microsoft Azure services is required if you use the service(s):
Verified:
  • AzureAD  (optional)
  • SPO / Graph API (optional)
  • LUIS NLQ Service (optional)
