Change log
November 01, 2026
Reference
Number
Type Summary
BMB-8037 Added options to currency data field configuration to specify the decimal delimiter and whether values enclosed in parentheses should be treated as negative. Numeric values are normalized based on these settings during document indexing. See Configure a currency data field for more information.
BMB-8497 Users are on longer required to clear their browser cache before logging into a newly released version.
BMB-10077 CloudFAX Integration: Fixed an issue that caused an error when accessing the contact list.
BMB-10910 Fixed an issue that caused an error when expanding a work item to view work item information.
BMB-10911 Added a When Deleted allow custom outcome option to the Advanced tab of the User Action workflow stencil configuration that allows you to route deleted work items to a specific step. See User Action stencil for more information.
BMB-11034 Fixed an issue that prevented some folders from displaying in the Microsoft Office 365 importer drop-down lists in some cases.
BMB-11048 Added a Custom field option in the Sort By drop-down list on the Advanced tab of the User Action workflow stencil that allows you to sort documents by a custom data field. See User Action stencil for more information.
BMB-11068 Fixed an issue where currency and decimal data types did not allow a X.0X value.
BMB-11079 Split documents now retain the creation date of the parent document and appear beneath it in the File Tree. Metadata, line items, barcodes, and annotations are also kept with the page.
BMB-11108 BMB-11109 The Document Panel no longer scrolls unexpectedly or automatically expands folders when new documents are imported.
BMB-11136 Fixed an issue where work items were orphaned from the workflow and could not be deleted after passing through an adaptive extraction step when there were more results than the number of data types configured.
BMB-11166 Added a new internal metadata key to track jobs submitted and uploaded from AccuRoute or HP Capture & Route.
BMB-11173 Invalid email imports now follow the failure path and move to the configured Failure Folder instead of being marked as successful and moved to the processed folder.
September 06, 2026
Reference
Number
Type Summary
BMB-9650 Added support for the Xerox device integration. See Xerox device integration for more information.
BMB-10056 Added substitution variables to report the number of signatures detected and the confidence percentage for each signature after a document has passed through a Detect Signature workflow stencil.
BMB-10245 Fixed an issue that caused adaptive extraction to fail in workflows when a tenant was not in the default region.
BMB-10269 Updated the password expiry warning message for the German browser language.
BMB-10488 Updated default user settings to avoid tenants being locked out when SSO is enabled and not configured correctly.
BMB-10610 Fixed an issue where the FileBound workflow stencil ignored the Workflow Route setting in the configuration.
BMB-10774 CloudFAX Integration: Fixed an issue where searching for a contact in a contact list added a duplicate entry to the list.
BMB-10777 Fixed an issue where the drop-down list for cascading fields was not displayed correctly in some cases.
BMB-10782 Fixed an issue that caused an error to occur when scrolling through the Work Items list in some cases.
May 17, 2026
Reference
Number
Type Summary
BMB-9660 Added a Failure Folder in the Importer settings for IMAP and Office 365 Importers.
BMB-10315 The download action is now a top-level button on the Toolbar.
April 12, 2026
Reference
Number
Type Summary
BMB-8996 Added support for the Xerox device integration.
BMB-9736 FTP connections are now validated when configuring the FTP workflow stencil rather than when a job is processed through the stencil.
BMB-9958 Fixed an issue where social security number PII detection only worked if the social security number had dashes.
BMB-10019 Fax and email importers will now retry on connection or authorization errors and be disabled for other types of errors.
BMB-10034 Added an 'Include Email Body' check box in the configuration for email importers and the Microsoft Office 365 importer. When selected, the body of the body of the email to be processed.
February 22, 2026
Reference
Number
Type Summary
BMB-8429 Added an 'Opacity' option to the Options tab in the Document Stamp stencil. This option allows you to specify whether the stamp is opaque or transparent when it is applied.
BMB-9380 Added a 'Merge attachments' check box in the configuration for email importers and the Microsoft Office 365 importer. When selected, multiple attachments will be converted into a single PDF before entering the workflow.
BMB-9415 CloudFAX Integration: Fixed an issue that caused an error to occur when exporting a large number of outbound faxes.
BMB-9458 CloudFAX Integration: Added support for downloading extremely large faxes (1000+ pages).
BMB-9670 Added support for line items in the Adaptive Extraction workflow stencil.
Note: The machine AI learning model has a practical output limit of around 2,500 words after system overhead. If results from a document exceed this size, line items appearing after the limit will be truncated and excluded from the return.
December 14, 2025
Reference
Number
Type Summary
BMB-8295 Fixed an issue where an error was displayed but the user was created anyway when a user was added with the same email address as an already existing user.
BMB-9379 Added support for HEIC files in workflows.
BMB-9497 Implemented a mechanism to prevent timeouts for long-running tasks.
BMB-9563 Fixed an issue where a password reset for a user logging in with an expired password was not working as expected.
BMB-9615 CloudFAX Integration: Fixed an issue that caused an error to occur when exporting a large number of inbound faxes.
BMB-9662 Emails and documents are always retained when a failure occurs during import.
BMB-9685 Fixed a certificate related issue where certain SAML and SSO users would get a 500 error when logging in.
BMB-9690 Enhanced the work items export process to handle a very large number of work items.
BMB-9694 CloudFAX Integration: Fixed an issue where Fax User Properties were blank for users with usernames that ended in ".CS".
BMB-9760 CloudFAX Integration: Fixed an issue where column values were incorrect in the exported file when a fax message was exported with specified columns in CSV/XML format.
October 19, 2025
Reference
Number
Type Summary
BMB-7360 CloudFAX Integration: Fixed an issue where users were unable to view and download a large fax in some cases.
BMB-9080 Updated the password reset message to a more generic and secure message.
BMB-9247 An error is now displayed when an importer is configured with the same username as an already existing importer.
BMB-9456 Improvements to UI performance.
BMB-9527 The Extraction Pro workflow stencil has been renamed to Multi-Table Extraction.
BMB-9528 The Classifier workflow stencil has been renamed to Advanced Classifier.
BMB-9529 The OCR+ workflow stencil has been renamed to ICR.
BMB-9531 Added an Adaptive Extraction workflow stencil which is used to automatically extract information from documents using a machine learning AI model and your Data Dictionary. See Adaptive Extraction stencil for more information.
BMB-9532 The Data Extraction workflow stencil has been renamed to Key Pair Extraction.
August 17, 2025
Reference
Number
Type Summary
BMB-8423 Document Stamp workflow stencil: When adding an image, the selected image is now displayed in Document Stamp Properties.
BMB-8426 Document Stamp workflow stencil: Added a Scale (% of original) setting when applying a stamp. The size of the applied stamp is based on this setting.
BMB-8428 Document Stamp workflow stencil: Rotation of an object now occurs relative to the object's center point.
BMB-8645 CloudFAX Integration: Font type and size are now retained when copying information into the Send Fax - Message box or Template body. Font type and size are not changed when highlighting copied content.
BMB-8768 CloudFAX Integration: Added icons to differentiate between private and shared contact lists in Send Fax.
BMB-8935 CloudFAX Integration: Fixed an issue where notifications were not sent when ownership was transferred and the Send message to user check box was selected. This option has been removed and notifications are automatically sent to the user.
BMB-9133 Document Stamp workflow stencil: The Barcode Value field now supports data field substitution.
May 18, 2025
Reference
Number
Type Summary
BMB-8023 Font names are no longer translated when the browser language is set to Japanese.
BMB-8024 Currency values extracted using the Invoice or Data Extraction workflow stencils have been updated to support EU numerical separators.
BMB-8164 CloudFAX Integration: Added the ability to share multiple faxes and the option to send a message to sharee(s).
BMB-8375 CloudFAX Integration: Added the ability to select columns when exporting faxes.
BMB-8644 CloudFAX Integration: Fixed an issue where notifications were not sent when transferring ownership of a fax and the "Send message to user" box was not selected.
BMB-8661 Added support for documents with more than 20 pages when using the Translate Document workflow stencil.
BMB-8694 CloudFAX Integration: Fixed an issue where the vertical bars used to resize the thumbnail view and the Fax Preview Window were not working as expected.
BMB-8720 Expression fields that are configured as data fields are now calculated before the job moves from an Invoice Extraction, Data Extraction, or Extraction Pro workflow step.
BMB-8723 Updated Invoice and Data Extraction workflow stencils to properly detect the key pair when using a Regex to determine the key pair name.
April 6, 2025
Reference
Number
Type Summary
BMB-7083 CloudFAX Integration: Added a tooltip for the document name in the Fax Preview Window and the Document Viewer that displays the entire document name.
BMB-7670 Added an OCR+ workflow stencil with advanced functionality that allows you to convert handwritten text into machine-readable text. See ICR stencil for more information.
BMB-7883 Added a Document Stamp workflow which allows you to apply a stamp to a document as part of the workflow. See Document Stamp stencil for more information.
BMB-8048 Added an Extraction Pro workflow stencil with advanced functionality that allows you to extract line items from multiple tables on a single document. See Multi-Table Extraction stencil for more information.
February 9, 2025
Reference
Number
Type Summary
BMB-7992 Line item rows in the Invoice Extraction workflow stencil can now be mapped to fields on a document other than those that exist in the extracted data for the row.
January 5, 2025
Reference
Number
Type Summary
BMB-6320 CloudFAX Integration: The Recipients field is autofocused after discarding changes made on the Send Fax page.
BMB-7808 Journal entries are now available for workflow items created by the Separation step.
BMB-7809 Journal entries are now available for workflow items created by a Classify and Extract step.
BMB-7810 Journal entries are now available for workflow items created by a Learned Automation step.
