Assignment Mode Setup
From the Setup tab in the Timesheet Template edit page, you can configure the Assignment Mode to either Inline or Modal Window for users of the New Timesheet. The Modal Window mode lets users select assignments via a popup window, as in previous versions. Inline mode enables users to choose assignments directly within the timesheet, streamlining the workflow and improving efficiency. This article explains .
This article details how to set the Assignment Mode at the Timesheet Template level to optimize the user experience
Caution: The article outlined here applies to the new My Timesheet.
. - From the Navigation Menu click Timesheet.
- From the available options select Timesheet Templates.
- From the Timesheet Templates list that displays, click the Name of the Timesheet Template you wish to access.
- Upon the Timesheet Template Edit page displaying, navigate to the Setup tab.
- From the Show Project Time section, select Inline or Modal Window Assignment Mode.
Note:
- Users can override the default Assignment Mode set at the Timesheet Template level by accessing their Display Settings from the Timesheet context menu
. - Modal is selected by default.
- Click Save and then Close.
View the impact of your changes when Modal is selected
Modal Window Assignment Mode allows Users of the Timesheet Template to pick their Assignments, from a modal window.
View the impact of your changes when Inline is selected
