Manage Summary Fields in a Timesheet Template
YYou can customize the KPIs displayed on users’ timesheets by adding or removing Summary Fields in their assigned Timesheet Template. Available KPIs include: Billable Hours, Future Planned Billable Hours, Future Planned Hours, Future Planned Non-Billable Hours, Non-Billable Hours, Periodical Minimum, Planned Billable Hours, Planned Hours, Remaining Periodical Minimum, Remaining Planned Billable Hours, Remaining Planned Hours, Remaining Weekly Minimum, Remaining Working hours, Total Hours, Weekly Minimum and Working Hours. Configuring these fields helps organizations tailor timesheet data to meet specific tracking needs, improving visibility and decision-making.
This article details how to add, edit, or remove Summary Fields in a Timesheet Template.
Caution: The article outlined here applies to the new My Timesheet.
. - From the Navigation Menu click Timesheet.
- From the available options select Timesheet Templates.
- From the Timesheet Templates list that displays, click the Name of the Timesheet Template you wish to access.
- Upon the Timesheet Template Edit page displaying, navigate to the Setup tab.
- Select Show Summary to display the selected KPIs in the Summary section within the User Timesheets.
- Click the New
icon in the table header. - From the Add Summary Item dialog box, choose a Field from the following available options:
Field Name Description Billable Hours Total Billable hours of Time Entries Future Planned Billable Hours * The Total Billable Hard Booked Hours for future periods until the end of the Project, excluding the current period. Future Planned Hours * The Total Hard Booked Hours for future periods until the end of the Project, excluding the current period. Future Planned Non-Billable Hours * The Total Non-Billable Hard Booked Hours for future periods until the end of the Project, excluding the current period. Non-Billable Hours Total Non-Billable hours of Time Entries Periodical Minimum (Available for Bi-weekly, Semi-monthly and Monthly Period types) Planned Billable Hours * Calculated as: The Total Billable Hard Booked Hours for the logged user for the current period Planned Hours * Calculated as: (The Sum of Hard Booking for each Project for the days defined in the period) Remaining Periodical Minimum Calculated as Periodical minimum - Actual hours (Available for Bi-weekly, Semi-monthly and Monthly Period types) Remaining Planned Billable Hours * Calculated as: Planned Billable Hours - Actual Hours Remaining Planned Hours * Calculated as: (The sum of Hard Booking for each Project for the days defined in the period) – (The sum of Actual Hours entered by the logged user for these projects) Remaining Weekly Minimum Calculated as: Weekly minimum - Actual hours(Available only for a Weekly Timesheet Period type) Remaining Working Hours Calculated as: Working Hours - Actual Hours - Non-working Hours Total Hours Total hours of Time Entries Weekly Minimum (Available only for a Weekly Timesheet Period type) Working Hours Total hours defined by the logged Users Calendar for the period Note: An asterisk (*) next to a field name indicates that the number displayed for that field in the Summary section is clickable. Clicking the number opens the Planned Hours dialog box, which displays detailed information pulled from the Work Plan. For further details refer to Accessing and viewing the Planned Hours.
- When adding a new Field the Language option is defaulted to English and con not be modified. You can change it when editing the Field.
- Enter a preferred name if different from that already showing, in the Display Name box.
Note: When the Display Name is overridden, it automatically overrides the System Terminology for that specific field only on the Timesheet Template.
- Select the Column Order number, from the available options, which defines the position in which the field is to be displayed in the table.
- When finished:
- Click the Close link to discard the addition and close the Add Summary Item window.
- Click the Save link to add the new field and close the Add Summary Item window.
- Click the Save and New link to add the new field. If the Save is successful, the field is added and the Add Summary Item window is refreshed to accept a new entry.
To edit a Summary Field
- To edit an existing Summary Field, click the Edit
icon. - The options available to you from the Edit Summary Item dialog box are the same as the Add Summary Item.
- From the Language options select a language to enter a Display Name for each.
- When finished:
- Click the Close link to discard the addition and close the Edit Summary Item window.
- Click the Save link to add the new field and close the Edit Summary Item window.
- Click the Save and New link to add the new field. If the Save is successful, the field is added and the Edit Summary Item window is refreshed to accept a new entry.
To delete a Summary Field
To delete a Summary Field, click the Delete
icon beside the item. -
Otherwise, multiple Summary Field options can be deleted simultaneously by using the global selection box and the Delete
